Discussion topic: Internet connection
This message was authored by: Ada+Inman
Internet connection
Constantly losing service from the WiFi not sure if it's a problem with the hub or not
Re: Internet connection
@Ada+Inman
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
