Discussion topic: Internet connection slow
This message was authored by: Krisbox
Our internet stopped working completely on Saturday morning. After power cycling it came back but since Saturday the upload and download speed has been much lower than it should be.
when tested at 21:36 download was 72.8mbps and upload 75mbps which is far off what we are paying for.
Re: Internet connection slow
@Krisbox the issue with soeedtests is that they return the slowest part of the connection which is likely to be the WiFi speed in your hiome. Sky test the speed to your hub daily and the results are in the Service Checker in the My Sky app. Assuming thst is OK your issue is poor WiFi signal in the area where the device was when you ran the test. WiFi speeds vary due to the layout and type of construction of your home.
