Discussion topic: Internet connection is **bleep**
Message posted on 03 Jul 2026 11:01 PM
My Internet connection keeps dropping out and buffering. All test come back saying no problem. However there clearly is.
Message posted on 04 Jul 2026 05:29 AM
Re: Internet connection is **bleep**
@Steve774
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Message posted on 04 Jul 2026 05:39 AM
Do you have a good wifi signal on the devices it keeps dropping out on ?
