Discussion topic: Internet connection dropping in and out
This message was authored by: SusanColman
Our WiFi was connected last week but we are still having issues
Re: Internet connection dropping in and out
@SusanColman whst issuesxare you having? Poor WiFi coverage  is probably the most common question we get in the forum. So is that is your problem?
In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
