Discussion topic: Internet and voice lights orange but service checker says no problems
Message posted on 15 Aug 2025 04:02 PM
Internet has been intermittently going down over last week or so. Internet and voice lights on hub are orange and we don't have Internet working but service checker says everything is fine when it obviously isn't.
Message posted on 15 Aug 2025 04:18 PM
Re: Internet and voice lights orange but service checker says no problems
@GR1997
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
