Discussion topic: Internet Not Working
This message was authored by: Phisix
Been down since 12pm and I have power on green, internet off, WiFi green and voice on orange. I tried the checker many times but says it cannot connect to the hub or it's not responding and it also says no on the sky hub connected? Part.
Re: Internet Not Working
@Phisix Use the help link's below!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
and about the lights is below, leads to the same place above!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
Avatar for Phisix
I have tried thanks but it's saying not connected or can't connect to the hub as shown below.
@Phisix If it will not let you book an Engineer then give sky a call to do it!
Avatar for Phisix
Will do thanks.
