Discussion topic: Internect connection
This message was authored by: Michelle58-
Although you say there are no problems with my Internet WiFi... and I have 3 x green lights on my router, I have no connection... maybe a new router is needed ??
Re: Internect connection
@Michelle58-
You aren’t communicating with Sky by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
