Discussion topic: Intermittent wifi
This message was authored by: HulaK
Intermittent wifi
Hi I'm having intermittent WiFi at the moment. The router connection drops out and the middle light flashes orange. There are no reported outages in my area but the connection has dropped 7-8 times over the past couple of hours. Any ideas? Sky FTTP has been installed and been exceptionally stable for past 3 years. Could the router be old and playing up? Frustrating when working from home and losing connection.
Avatar for HulaK
Re: Intermittent wifi
Should add that the service checker says everything looks good and is green.
This message was authored by: Diwlsn
Mines doing the same. Says everything is ok on the checker but I have an orange light on the box. Been going on and off all day
Avatar for HulaK
I'm Manchester based if that helps. Don't know if there is an outage that's not been reported in the area.
