Discussion topic: Intermittent loss of connection
Message posted on 24 Dec 2025 03:52 PM
Hello
A couple of times a day I temprarily lose connection to the internet. At that point i restart the router and it comes back.
What do you suggest I check?
Merry Christmas,
Veronica
Message posted on 24 Dec 2025 03:56 PM
Re: Intermittent loss of connection
@VTBa This would be a start especially when the system has stopped working!
Try running the line test here to see if any faults are found:
