Discussion topic: Intermittent internet outages 7th Feb
Message posted on 07 Feb 2025 03:35 PM
Internet has been dropping in and out all day, the Service Checker keeps saying there is no issue at times that no device can connect and when orange light is flashing on the router
Message posted on 07 Feb 2025 04:04 PM
Re: Intermittent internet outages 7th Feb
@Hope21
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
Message posted on 07 Feb 2025 04:11 PM
Thanks Daniel, I did try both the links mentioned and it kept returning no issues - even though there was no connectivity. Usually the diagnostic tools have been helpful but seems today they were giving false results.
Hopefully it will remain stable now
