3
This discussion topic has been answered Discussion topic: Intermittent connectivity
This message was authored by: RichB24
My internet keeps dropping. I've checked router logs and it think it could be DNS related as I'm seeing logs such as TR69 Connect to ACS Failed: Could not resolve host
Avatar for RichB24
This message was authored by: RichB24 Answer
Re: Intermittent connectivity
Thanks for the replies. It turned out to be an external fault on the line outside the house even though the sky broadband checker said everything was good. Sky called OpenReach out who sorted the issue.
@RichB24
Try running this line test to see if it finds any faults:
If this is of no help give Sky a call to report it to them.
@RichB24 TR69 is sky checking the sky Hub to record the speed that it is seeing for the daily log, you will find that once per day and near enough the same time daily it happens!
Avatar for RichB24
