Discussion topic: Intermittent connection
This message was authored by: Farhood
Hi,
the speed on my broadbandnis good and the pod which is in the living room works fine but when im closer to the main hub in the primary bedroom, the wifi signal drops and i dont get internet connection anymore! Not sure what the problem is but the wifi will drop every 2 minutes
Re: Intermittent connection
Hi @Farhood
When you say closer to the main hub... how far exactly? It might just be that your closer to the main hub than the pod but still out of WiFi range.
I am NOT a Sky Employee
