Discussion topic: Intermittent connection and poor internet.
Message posted on 18 Nov 2025 11:08 PM
Over the past 48 hours we have been getting irregular connect to our Wi-Fi router, however the router has always had the green light on. But on all devises connected the internet keeps disconnecting.
on top of that when we are connected to the internet it is extremely poor and struggles to load webpages at times.
i have run a check on issues and broadband speed via the sky website but it says there are no issues at all, the router is fine and we have ultra finer connection with high download speeds.
something is clearly wrong but nothing is adding up to a clear issue. There must be a larger issue as other people on this form today have said similar things.
Message posted on 19 Nov 2025 05:33 AM
Re: Intermittent connection and poor internet.
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
