Discussion topic: Intermittent broadband
This message was authored by: Bill672
WiFi connect but today the connection to the internet has been dropping every hour. I've reset everything but it is still happening.. Anything you can suggest?
Re: Intermittent broadband
@Bill672 Would help a little if you said what, take a look at the help link below and say what you see, also linked is the diagnostic test below that to try!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR ONT also require to be looked at!
this will check below!
