Discussion topic: Intermittement broadband connection
This message was authored by: RobWood86
My connection keeps dropping and making it hard to work. I've tried the checks from Sky connection checker but it says its 'good'
Re: Intermittement broadband connection
@RobWood86
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
