Discussion topic: Interet not working
This message was authored by: JD67
Interet not working
Hello,
My Internet has stopped working. The power light on the router is green, but the Internet light is orange, the wifi light is orange, and the voice light is orange. I've switched the router on and off and it does the same thing. Can you help please?
Re: Interet not working
@JD67
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
