Discussion topic: Inter net
This message was authored by: Simonmiddleton
Inter net
We keep loosing inter net
Re: Inter net
@Simonmiddleton
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
