Discussion topic: Installation Date
Message posted on 24 Mar 2024 01:27 PM
Installation Date
Message posted on 24 Mar 2024 01:37 PM
Re: Installation Date
@Andyuk70 What is the package that you took with Sky, this might give us information that can help you. Was it superfast or ultrafast?
Message posted on 24 Mar 2024 02:33 PM
Message posted on 24 Mar 2024 04:05 PM - last edited: 24 Mar 2024 04:07 PM
@Andyuk70 The reason for the 25th visit is most likely to do outside work that is needed before the install date of the 28th.
This is the optical fibre connection to the outside of the property and the inside work completed on the 28th
