13 Apr 2023 10:03 AM
Hi everyone,
I have used Sky Broadband Shield with success, even the exceptions seem to be working pretty well.
There is only one service that manages to bypass the filter: instagram.
Has anybody been able to block instagram successfully?
When adding to the exceptions I use "instagram.com".
Kind Regards,
Matteo
13 Apr 2023 02:12 PM - last edited: 13 Apr 2023 02:19 PM
@M+A+T+T wrote:
Is there any way to block access to an App?
Unfortunately it isn't easy because an app can (and typically does) use methods other than a domain name lookup to reach its servers.
You could try changing the age setting on Shield, but this will obviously affect all internet access for every user at the address which probably isn't ideal.
13 Apr 2023 12:21 PM
Posted by a Superuser, not a Sky employee. Find out moreIf that's Instagram in an app, domain name blocking is unlikely to be effective.
13 Apr 2023 12:25 PM
Hi there,
You are correct, instagram is blocked when accessed within a Web Browser, but mobile Apps are not blocked; I have just realised that to be true also for other apps.
Kind Regards,
Matteo
13 Apr 2023 02:18 PM
I think I could make it work for the time being, I'll give it a go.
Many Thanks!
Matteo
