Discussion topic: Incredibly unstable ping for weeks
Message posted on 29 Mar 2026 01:45 PM
I've had a presistent issue with latency and randomly being on 150+ ms for hours at a time. It's been a thing for weeks. I'm not the account holder, the internet is "online" and the TV works, so my tech illiterate father doesn't see an issue. I work from home and game a lot, so having an unstable connection has been very very annoying.
I'd like to know if this can be resolved online, or if someone at Sky can do a service check for me.
Message posted on 29 Mar 2026 01:53 PM
Re: Incredibly unstable ping for weeks
@flootdesigns wrote:or if someone at Sky can do a service check for me.
Sky won't talk to you as you're not the account holder, presumably your father is.
If there are broadband issues the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 29 Mar 2026 02:02 PM
Well that's annoying, since my father is aware of the issue yet won't do anything as the internet is technically working and the TV is working. I can't run a service check since I can't log into his account. Roll on September when FTTP is orderable so I can get rid of this garbage.
Message posted on 29 Mar 2026 02:06 PM
Only the account holder can cancel or agree to an alternative subscription.
Message posted on 29 Mar 2026 02:12 PM
I'll be getting my own line in my own name this time. Only reason I haven't already is because paying £40 a month for a copper cable at 15Mbps is absolutely not worth it in the slightest.
Message posted on 01 Apr 2026 05:58 PM
Now on day 3 of Sky denying any issues in the property, despite having borderline unuseable internet the entire time. Getting fibre on the 15th thank god.
Message posted on 01 Apr 2026 06:13 PM
A domestic ISP typically isn't going to look at latency. They 'guarantee*' a minimum download speed at the router and that's about it.
* i.e. not really: what's actually guaranteed is a small refund if the quoted speed isn't delivered.
