Discussion topic: Incorrect Password
This message was authored by: richylinford
Message posted on 26 Sep 2025 08:38 PM
Incorrect Password
Whenever i try to connect a new device like in this instance my smart TV, it keeps saying 'Incorrect Password' i type the password in exactly as it is on the back of the Sky Hub but the Tv won't connect
Find out more
Message posted on 26 Sep 2025 10:31 PM
Re: Incorrect Password
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as show on the hub itself so use upper case letting if required.
