Discussion topic: Inconsistent wifi speee
Message posted on 02 Jun 2025 09:18 PM
Message posted on 02 Jun 2025 09:29 PM
Re: Inconsistent wifi speee
@Kai159 Are you completely wireless for all devices connected to the hub, the 150Mb/s is for everything that is sharing at that time, so a couple of 4k TV watching could be gobbling up 80 to a 100K, but you do say single testing.
If you web to the hub and look at the stats's while running you can watch how busy the network is. Tip link above explains how to get to the stat's.
Watching it wired is best but if you are only wireless then that is all you can do.
Message posted on 02 Jun 2025 09:43 PM
Message posted on 02 Jun 2025 11:01 PM - last edited: 02 Jun 2025 11:03 PM
@Kai159 Once you get the better idea what is going on, wan stat's is all the devices then you have the other 3, Higher bandwidth would help, but speed is as good as the slowest, bit of a see-saw effect, number off devices, and what is going on is more important, stability is the must over speed always...
If you want some heavy reading then www.wiisfi.com and download the doc or save a copy read at your leisure.
Message posted on 03 Dec 2025 09:59 AM
Hi how can I purchase booster
Message posted on 03 Dec 2025 10:06 AM - last edited: 03 Dec 2025 10:07 AM
@Hellen005 That depends on the type of sky hub that you have, the link below for sky's varient is the Sky Max system, but it is an addon to any package unless you have that already. Info is all linked below for you! There is NO outright purchase off any sky Equipment!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
