		Discussion topic: Inconsistent connection
	This message was authored by: DomBarnes
		Message posted on 28 Oct 2025 07:25 PM
Connection drops on web calls, Zoom meetings. It recovers but it shouldn't be dropping.
Find out more
		Message posted on 29 Oct 2025 06:48 AM
							Re: Inconsistent connection
@DomBarnes the modt likely cause is poor wifi signal reaching the device. If you can definitely rule thst out then check the. Lights onnthe hub when you lose connection but thst is far less likely than poor wifi.
