Discussion topic: Inconsistent broadband
This message was authored by: PortStMaryBoy
Getting a really inconsistent service .
all sky's checks tell me all is fine but it's plainly not.
anyone else having issues?
Avatar for PortStMaryBoy
Re: Inconsistent broadband
I currently have no broadband connection (I have turned off WiFi to type this)
I can connect to my router and have made no changes for literally years
Vurrently trying to figure how to log a ticket 😖
@PortStMaryBoy
If the service checker is still not telling you that Sky are aware you may need to call them in the morning to report it (dial 150 free from your Sky Talk landline).
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
▪️I AM NOT A SKY EMPLOYEE ▪️
Thank you 🙏
