Discussion topic: Im having issues with internet
This message was authored by: OnesieBun
I know I'm not the only one but I'm in Scotland and I'm having troubles with the internet the status on sky is saying no problems but my internet is cutting off and I was in the middle of watching squid game and I get internet problems like plz fix this 😭
Re: Im having issues with internet
@OnesieBun
You aren’t contacting Sky Customer Services on here. We are mainly customers trying to help other customers.
