2
This discussion topic has been answered Discussion topic: Ignorant engineer.
This message was authored by: Mrfobof
Ignorant engineer.
Am I wrong to expect my phone to be connected when I had broadband connected.That [Removed] engineer has left me with no landline.
Moderator notes: Removed rude remark
Re: Ignorant engineer.
If it was previously in a wall socket (master or extension) then that's not going to work any more.
This is an inevitable side-effect of voice telephone service transitioning from analogue to digital before PSTN is switched off nationally in about a year from now.
As @caesarome indicates, one handset or a DECT multi-handset base station should be plugged into the phone socket on the rear of the Sky Hub.
@Mrfobof
Are you able to connect it yourself as it should plug into the back of your broadband hub.
