21 Oct 2023 02:27 PM
Hi, I'm looking at cancelling my broadband and moving to a fibre company. If I do so, however, do I lose my mobile with sky as well or is it possible to keep the mobile independently to any other sky services? Thank you
21 Oct 2023 02:29 PM - last edited: 21 Oct 2023 02:30 PM
Your mobile is in no way dependent on having sky broadband. You are able to retain your mobile
21 Oct 2023 02:31 PM
Thank you @cookiemonsteruk
21 Oct 2023 02:34 PM
Just be aware of any early termination charges if you cancel with in your minimum term 👍
Anyway what has you thinking of moving broadband?
21 Oct 2023 03:12 PM
Cheaper with a different provider and full fibre
21 Oct 2023 03:18 PM
I am assuming the provider isn't using openreach for infrastructure
Also be aware that you need to contact sky to cancel and the new provider seperately if they don't use openreach
Could you enter your full postal address below and post the table after removing your address from the image. It will show openreach infrastructure before isp's get hold of it
