Discussion topic: IMPOSSIBLE TO FIX MY INERNET.
Message posted on 14 Dec 2025 01:23 PM
Okay so ive had isssues with my broadband speed since 2023, it ranges from the internet completly dying, slow to almost zero wifi speed.
Recently we have had a technichian over and he gave use a new wifi router, 2 more sky boosters and did some tweaks.
All looked good until i tried to play any game, i raange from 15 ping to 300 ping in seconds and ONLY play lan.
I dont know what to do anymore, im in constant contact with support.
If anyone has a solution please help as i will try any method at this point.
Thanks for your time,
Kind regards, Tommy.
Message posted on 14 Dec 2025 03:59 PM
Re: IMPOSSIBLE TO FIX MY INERNET.
@TommyGw Why don't you turn your boosters off when you game?
