3
This discussion topic has been answered Discussion topic: I thought I was going mad
This message was authored by: Purplelinds
  • Internet down in Heysham since 11.30 been trying to reset but it's sky again but they say all is normal not this time not paying for this as it's happening a lot drops then come back on and then drops again been given a boost but not that help with mini box
Re: I thought I was going mad
@Purplelinds
I've moved your post to the Broadband board.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
@Purplelinds
This message was authored by: Me134
Don't be tempted to stop the direct debit as that will cause you much more anguish than it will Sky.
If you have the WiFi Max add-on you can contact them and request an engineer visit who may fit up to 2 more extenders to give you better WiFi coverage around the house.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
@Purplelinds wrote:
  •  been given a boost but not that help with mini box
Unfortunately the WiFi from a Max booster pod cannot be used by a Q Mini box.
