Discussion topic: I nternet
This message was authored by: JadeStacey
I nternet
I have no Internet
Re: I nternet
@JadeStacey
It could be overnight maintenance taking place.
If it still down later then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Re: I nternet
@JadeStacey
When there are issues between midnight and 0700 it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still down after 0700 and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
