Discussion topic: I need wifi booster
This message was authored by: Mohammad92
I need wifi booster
I need Wifi booster because the signal is too low in two rooms
Re: I need wifi booster
@Mohammad92
If you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Having more than one will require an engineer to set them up for you.
