Discussion topic: I need help
Message posted on 02 Jan 2025 03:36 PM
I need help
My internet started dropping out yesterday. I believe this has been an issue in the area. As people were asking on FB yesterday saying they had thh uh e same issue. I have done everything to resolve as in turn on and off, unplug everything and then putting it back on. Still not internet light is coming on my router. The app is saying everything is fine, when it's not
Message posted on 02 Jan 2025 05:45 PM
Re: I need help
The first thing to do is check to see if there are indeed any outages nearby via this link https://www.sky.com/servicechecker
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
Once completed, if it reports back that all is good click on 'broadband' to run an updated test.
If you get amber or red you need to follow the on-screen instructions.
