Discussion topic: I need another sky max pod
Message posted on 23 Aug 2026 01:50 PM
I need another pod in my kitchen. I'm getting a smart outdoor light above the back door. The pod I have just now helps with my doorbell connection. Once I go out the back door my signal drops. I'm disabled so I need a solid connection to the light. Thanks
Message posted on 23 Aug 2026 02:00 PM
Re: I need another sky max pod
You will need to do as you did before and contact Sky, having more than one will require an engineer visit to fit it for you:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
