Discussion topic: I know what is missing to connect WiFi however I now do not have the yellow cable since I’ve upgrade
This message was authored by: Higgins1
Connection with WiFi
Re: I know what is missing to connect WiFi however I now do not have the yellow cable since I’ve upg
@Higgins1 not very clear but if you are missing a cable you can buy a replacement locally very easily. The type you need depends on what is connecting to what.  The two main types are the cable to connect between the phone socket and the hub on a partial fibre service which is known as. DSL cable with rj11 connectors. The second connects between the ONT unit with lights and the hub on a full fibre service shich is an ethernet cable with rj45 connectors.
Both  can be bought at hardware stores or major sipermarkets. The colour is not important.
