Discussion topic: I have no internet connection
This message was authored by: Emmaz1
I have been without Internet connection for nearly w4 hours now, done all off the things asked via sky (online) rebooted, restarted, turned every thing off ample times, been doing this different times threw out the day between work, verry stressful online checks saying everything is working good but obviously is a problem, carnt find a contract number to talk to an actual person for help with sky ( verry difficult when not technical)
Re: I have no internet connection
@Emmaz1 If you have a sky mobile it's dial 150, if you have a sky talk working landline phone then it is also 150! And by time now the link below may be able to help!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
