Discussion topic: I have no internet connection
Message posted on 28 Sep 2025 06:53 PM
I have lost my internet connection so my tv and devices are. It connected
Message posted on 28 Sep 2025 07:04 PM
Re: I have no internet connection
@Lindacarey
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
