Discussion topic: I have no Internet connection
This message was authored by: Sal41
I have power to my hub and the green light is on on the Wi-Fi but no green light on the Internet connection I have tried resetting checked all the connections still not working
Re: I have no Internet connection
@Sal41
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
