Discussion topic: Hub
This message was authored by: JuneDD65
Hub
Do I need to return my hub to Sky as I no longer  have sky broadband.
mid so where do u send it
Re: Hub
@JuneDD65
You might need to return it as Sky usually sends packaging out near the end of the cancellation notice period of 14 days for Broadband/Talk so if you haven't received it then you can use whatever boxes you have or can get as this link will help you to print the return label and return it via Royal Mail:
https://www.sky.com/help/articles/return-tv-broadband
Add a note inside with your account number and a list of equipment you have included.
Make sure you get and keep proof of posting when sending this off.
