Discussion topic: Hub setup
This message was authored by: KaiBurden
Message posted on 17 Jul 2026 02:23 PM
Hub setup
When trying to set our hub up that got installed today, I'm on the my sky app, pressing the blue setup box, when pressed a blank white tab opens up but never loads. Without this tab I can't setup my WiFi.
Find out more
Message posted on 17 Jul 2026 03:08 PM
Re: Hub setup
@KaiBurden you dhould be able to network your devices either by using the QR code on thevhub or by entering the passcode onnthe label. Reboot the device you are using tomrun the app but if dtill,stuck givecSky a call.
