Discussion topic: Hub setting
This message was authored by: Jules_1
Hub setting
Hi I'm looking for my username and password to login to gateway settings to change my ghz to 2.4 for my tapo security cctv. Does anyone know how to do this Regards
Re: Hub setting
@Jules_1
The username is admin.
The password is either sky or more likely your Wi-Fi password that is printed on the hub itself.
Avatar for Jules_1
Re: Hub setting
Hi
I've tried Admin for username and sky for password
also tried Admin and wifi password with no success
Re: Hub setting
@Jules_1 The username is admin, just as you see it, NO capital A!
