Discussion topic: Hub not working
This message was authored by: Saba2
Hub not working
The broadband not connecting to any device or showing when u want to connect it
Re: Hub not working
@Saba2
If you mean you can't see your Sky wifi network on any device then are the lights lit as normal on your hub or are any out or flashing ?
Avatar for Saba2
Re: Hub not working
The broadband have no light show. When you connect on a mobile the name of the hub doesn't show too. Hub is showing as offline when I look at show my device on sky app.
Avatar for Saba2
Re: Hub not working
The broadband have no light show. When you connect on a mobile the name of the hub doesn't show too. Hub is showing as offline when I look at show my device on sky app. I have turned it off for few minutes too. My landline shows line cord error
This message was authored by: Me134
Re: Hub not working
Hopefully this has resolved itself overnight but if not, do you have FTTP (fibre to the property)? If so you'll have an ONT (small white box) on the inside of your house that the hub plugs into (there are various makes, so look for the correct one in the pictures). Have a look at the following and see if that helps.
https://www.sky.com/help/articles/optical-network-terminal
If not, find your hub on the following and see if that helps explain anything.
Edit: BTW, try unplugging both the ONT (if there is one) and the hub for at least 10 minutes before turning the ONT on first and when it's settled down, the hub.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
Avatar for Saba2
Re: Hub not working
Thank you for everyone's help. Had to call sky. Router may need to be replaced.
