Discussion topic: Hub not working
This message was authored by: Boldero
Hub not working
Help keeps dropping out losing Internet constantly have to keep rebooting it and Wi-Fi don't work will need a new hub
Re: Hub not working
@Boldero
You don't necessarily need a new hub.
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
▪️I AM NOT A SKY EMPLOYEE ▪️
