Discussion topic: Hub not arrived
This message was authored by: cooter29
Hub not arrived
My superfast due to go live on Tuesday but router has still not been despatched.
Getting a bit tight now for delivery before openreach come to activate
This message was authored by: Waveman
Re: Hub not arrived
Your Hub is dispatched to arrive the a day or two before, they are usually timed quiet tight!
Does your order tracking say that youre getting a hub, if you are already a customer your existing hub may be sufficient and you wont get a new one.
I remember the Internet starting!
Sky Full Fibre & Virgin Media XGS-PON, with automatic failover using DrayTek multi WAN router.
Sky Q, which will be sadly missed when they decide to kill it off!
Re: Hub not arrived
@cooter29
Hubs are normally dispatched via Royal Mail to arrive a few days prior to the activation date.
Once sent out you can usually track its progress. The postie will usually leave it hidden if no one is in. You don't need to sign for it. The postie should also pop a card through the letterbox telling you where it was left and the tracking should show some information on it too.
