Discussion topic: Hub max restart
Message posted on 03 Oct 2026 04:24 PM
Hub max restart
Any ideas, my hub max restarts once a week usually on a Saturday or Sunday. It's located in the open so is cool and showing no outages in the area.
the restart only takes around a minute but just stumpedwhy it would randomly restart once a week
Message posted on 03 Oct 2026 04:48 PM
Re: Hub max restart
@Ray+from+the+bay occasional resets are not unusual but they usually happen overnight but can happen during the day if the hub is powered down at night. Otherwise is therecan issue with a loose cable or g=dodgy power connection?
Message posted on 03 Oct 2026 05:22 PM
Re: Hub max restart
Thanks will check all the connections and monitor
