Discussion topic: Hub keeps disconnecting from Internet
This message was authored by: Steve10661ŵ
Message posted on 27 Aug 2024 09:25 AM
Our hub keeps dropping connection several times a day
Find out more
Message posted on 27 Aug 2024 10:34 AM
Re: Hub keeps disconnecting from Internet
@Steve10661ŵ Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
