Discussion topic: How to setup sky bordband
This message was authored by: Lokraj
 I have this type of fiber connector can I connect sky net broadband
Re: How to setup sky bordband
@Lokraj
What package have you gone for?
@Lokraj  Your picture shows a master socket for a copper line, not a fibre connection.
This message was authored by: peter-marlow+1966
If you have  gone for fftp broadband  then you need  to have fibre  optic cable fitted  and an optical  network terminal box  to like this and a grey box somewhere  outside of your  property
P c marlow
This is the grey box outside of my  house
 the fibre optic cable comes from the telegraph pole to the box and then from the  box into the house to the  optical terminal network box  in my  living room
P c marlow
And an older one at that: the stylised 'T' logo is from the 1980s ; )
That socket  is a cooper phone  line connector not a fibre  optic cable  box
P c marlow
This message was authored by: Sayek
Damn...I have not seen these phone sockets for a while
@Lokraj
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is available.
