Discussion topic: How to remove automatic sky VPN in my wifi?
This message was authored by: grv1360
Sky wifi Automatically applying a VPN - for e.g. netflix not showing local titles. Help?
Re: How to remove automatic sky VPN in my wifi?
@grv1360
There is no VPN.  It's possible that you've been allocated a public IP address which is currently not registered as belonging to Sky
Avatar for grv1360
Thank you.
how do I resolve it?
@grv1360
One thing to try is unplugging the router from its mains supply for an hour.
Avatar for grv1360
Thank you, I tried that but not sure if that worked.
Is there a way for to figure out if my IP address is a public one or registered to Sky?
