Discussion topic: How to get Sky Max Boosters?
This message was authored by: JW103u37172728
I just upgraded to Sky Max WiFi. This was because there are certain places in my house that are out of range of my router, and part of the Sky Max WiFi offer is up to 3 booster pods. I processed the upgrade, lo and behold I receive a new hub - no boosters. Same issue as before. Online recommendation is going to the room without signal and running a test. Unfortunately, when I'm in said room - I have no signal, and therefore the test cannot be run.
Re: How to get Sky Max Boosters?
@JW103u37172728 You do not get any boosters sent, you need to call sky for your 1st and the 2nd/3rd require a sky Engineer visit!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
