Discussion topic: How to book an engineer
This message was authored by Rtpannell1 This message was authored by: Rtpannell1
I have recently brought a new property and changed provider to sky. I cannot get the router to connect to the internet after undertaking all the relevant tests. I have tried to call customer services and use the automated assistant does anyone know the easiest way to get an engineer to visit my property to resolve please?
This message was authored by TechmanagerMal This message was authored by: TechmanagerMal
Re: How to book an engineer
  • Please follow the advice below
  • As we are customers on the forum we can only provide advice.
    However, if you want to discuss an issue with Sky, for the general-purpose number click on "Need more help" at the bottom of this page
    https://www.sky.com/help/home.
    If you are in the ROI set the flag at the bottom of the page accordingly.
    If you have Sky Talk or Sky Mobile dial 150 for a free call to Sky.
  • When you call you will be asked if the call is to do with mobile say "No"
    You will then be asked the nature of the call say " Technical "
    You will be offered a text to the number you are calling on, say "Yes" and a text will be sent DO NOT hang up when it says to do so.
    It will then ask "do you wish to hang up" say " No" you will then be put in the queue for an advisor.
  • I hope this helps.
Passing on the tips I have learned in over 24 years as a more than satisfied Sky customer.
Has your activated date been and gone, if so try running the broadband test via this link:
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
