Discussion topic: How do i oreder a wifi booster
Message posted on 11 May 2026 09:22 PM
I have fitted a sauna with a WiFi heater and the WiFi doesn't reach that far.
We also don't receive a signal on pre mobile phones.
The distance is apox 20m from the rounter and it can't be moved
Message posted on 11 May 2026 10:19 PM
Re: How do i oreder a wifi booster
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
